B16A Ignition Coil Service ?
Discussion in 'General Tech and Maintenance' started by natecspecr, May 31, 2005.
  1. natecspecr
    natecspecr Member
    Hi sir,
    Need your help on this matter . Actually when do we need to do service on the Ignitio Coil ( Distributor coil ) ? or changing the carbon brush inside it ? And if the ignition coil got problems what symptoms will it show ? Isnt the rpm will shaking ? or spark plug firing not accurate ?
    Thank you .
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    You got the symptoms right.
    There is no definite time for changin the coil. Some die in months and some take years.
