Start here ...
Swap Articles - HondaSwap Forums
You car being automatic you can either convert to manual, or get an automatic B16A transmission. The conversion is a bit of work, you have to add the pedal set, the clutch lines, master cylinder, change the bracket on your car too I believe, but someone might make a mount that can use the auto bracket, not sure.
