NO SPARK!!! I have a 94 teg with a b16a obd 1 with a p30 computer. car was an auto and is now manual. main relay clicks, fuel pump comes on, turns over and has compression. Everything is hooked up minus some extra plugs that go nowhere. all grounds good and getting power to the dizzy getting about 10 or 11v out of the igniter output at the pcm. Engine turns over and i get plenty of fuel. new wires plugs no corrosion on the dizzy cap or rotor all leads connected in the cap double checked the timing and it is right. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
