B16A Max Power ??
Discussion in 'Forced Induction' started by amadeuscr, May 7, 2008.
  1. amadeuscr
    amadeuscr Member
    hello people , I wanted to ask how many whp I can take out from my engine and be safe at the same time .
    I have this:
    b16a JDM
    stock sleeves
    eagle rods
    wiseco pistons forged
    Turbo Kit - t3/t4
    2.5 inch exhaust pipping
    TiAL 38mm wastegate.
    450cc DSM injectors
    Walbro fuel pump
    Tunning with CROME PRO.
    I am currently with 282whp and 193lbsft of torque at 10psi , I know that at this point I need to change injectors but I dyno it last week, Im installing this week the walbro too. my goal is probably 350whp , a little less don't hurt ! , thanks in advance for the help.
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    It wouldn't hurt to put another 6psi ontop of the 10psi your running now, should get you to your goal if not a little more. Just upgrade the fuel system to compensate for the increase in boost, and have it dyno tuned again.
  3. amadeuscr
    amadeuscr Member
    I forgot to mention that I am using stock head gasket and stock head
  4. t3t4delsol
    t3t4delsol New Member
    York, Pa
    I would start to worry about using the stock head at that kind of hosrepower, I would atleast get a mild port and a 3 angle valve job. Did you install some arp head bolts?
  5. amadeuscr
    amadeuscr Member
    I have stock head bolts , I was thinking about installing cometic head gasket , arp bolts , and 750cc injectors !! and start from there , what do you think ?
  6. t3t4delsol
    York, Pa
    atleast get arp, or I guarantee your will get head lift after a while, the stock head gasket is fine. but if you do decide to replace it I would get atleast a mild port and a 3 angle valve job
  7. efhondakid
    Akron-Canton, Ohio
    350-400 is about all the stock sleeves are good for isnt it?
  8. amadeuscr
    amadeuscr Member
    I know stock fuel pump wont work , I realize it when I was tuning, I installed a bigger one , but don't know the brand, and that one worked good for a while, but I already bought the walbro , cause I want to be sure of what I have , I am installing it this week,
    So buy list is ARP , cometic head gasket , and injectors ?
  9. rlhernandez86
    rlhernandez86 New Member
    The Big O
    I dont know if i heard right but i thought they said that b16 blocks are kind of crappy? Not trying to whore your thread bud
  10. LS_VTEC
    NJ
    B16 blocks are crappy for all motor setups. The most NA power ive seen out of a b16a was 200whp, and that was with some SERIOUS head work and cams not to mention the higher compression pistons.
    Boost on the other hand is a different story. You can boost a stock b16a engine with a t3t4 50 trim and make 250whp tuned on 10psi. Thats some serious fun on the street, but I prefer something along the lines of 350-400whp for the street, IMO.
  11. amadeuscr
    amadeuscr Member
    I did 282whp and 193lbsft of torque with 10psi ! :rolleyes:
  12. amadeuscr
    amadeuscr Member
    I have a question about all this , I have seen people with 12psi and with hp not even close to what I got, using similar setups (forged pistons and rods ) , I have a friend that dyno tuned he got 266whp at 12psi , I believe that if I put 12psi I get at least 300whp, cause I made 282whp at 10psi , and I am talking about the same engine (b16a)
  13. amadeuscr
    amadeuscr Member
    People , I need it to add something , I know is not directly related to the subject , but I was changing the fuel pump and I took some time to check my injectors, the guy who sell those to me told me that were high impedance ! , and I believed him (big mistake) , yesterday I was checking Ohms on the injectors and apparently they are low impedance (3.5ohms) , high impedance should be around 12ohms (correct me if Im wrong) , so there is two things I wanted to check ...
    1st : I bought a Si 91 civic resistor box , it has 5 wires, one red , and 4 black, the 4 black should be connect it to the injectors (yellow/black) , and red should be connected to only one line that comes from the ECU ? , having in mind that there are 8 wires total, 4 wires that comes from the injectors(yellow/black) and 4 wires that comes from ECU ( I Think , lightyellow/black ) , 1 from this last 4 is real signal (ECU) and what are the other 3??
    I install the box this way : all 4 wires (comes from ecu lightyellow/black) all togheter to the red wire on the resistor box, and the 4 black wires directly to the injectors (yellow/black).
    2nd: I used those low impedance injectors without resistor box for more than a month , I know that can be fatal for the ECU . but is working now no problem aparently , is the ECU ok ? or even if it's working , could be damaged by now ?
  14. BrutalB83
    Rochester Hills, MI
    Nice! :lmao: Did you make that yourself?
  15. LS_VTEC
    NJ
    Some setups can operate your way without a problem. To be perfectly honest with you, if it were to burn out the ecu, it would have done so within roughly 10 minutes.
    *If you look at the specifications of the injector driver package, it indicates it can flow the amount of current required for low impedance injectors.*
  16. schleht
    schleht Automotive Addict
    Are you running an aftermarket Fuel Pressure Regulator? If so, what brand and type of FPR is it and what does the fuel pressure rise per pound of boost?
  17. amadeuscr
    amadeuscr Member
    I know psi is not a good base to say how much power you are going to get , but the difference is too big !
  18. amadeuscr
    amadeuscr Member
  19. amadeuscr
    amadeuscr Member
    the only thing I don't understand from yours is that only one line comes from the ecu to the red wire on the resistorbox , in my case I have 4 (obd1)
  20. amadeuscr
    amadeuscr Member
