B16a not accepting boost
Discussion in 'Forced Induction' started by gatto-is-alive, Mar 4, 2009.
  1. gatto-is-alive
    gatto-is-alive New Member
    EARTH
    i instaled a turbo on my b16 this week and today i got it out for a run but the engine is not accepting boost .when the boost goes up to 3psi the engi is like slowing
  2. get_nick
    Washington State
    have you tuned it?
  3. Matts96HB
    Matts96HB . Moderator VIP
    Guessing it's untuned. Probably on a stock ECU, so you're running extremely lean. Do not run the car like this. Get it tuned, and then try again.
  4. gatto-is-alive
    EARTH
    yes all stock and untuned.
    how can i tune it?
  5. gatto-is-alive
    EARTH
    i'm going to install a 5th injector is that good or not?
  6. get_nick
    Washington State
    wtf is a 5th injector going to do???
    heres the deal. your car is NOT stock anymore. your car is running a STOCK ecu. think about it. you need to get to a shop and have them tune it.
    also, why the hell did you do a turbo setup and not know that you need to tune it?
  7. gatto-is-alive
    EARTH
    so will i have to change the ecu or what?
  8. get_nick
    Washington State
    really? are you serious?
    i'm going to ask you a legit question. who installed the turbo on your car?
  9. gatto-is-alive
    EARTH
    i installed any thing by my self but i dont know how the electonics of the car works so thats the reason of the quetion
  10. get_nick
    Washington State
  11. Matts96HB
    Man, if you continue to drive that thing, your B16 is going to be toast.
    If you listen to one piece of advice, just park the car until you get a tune on that thing.
  12. gatto-is-alive
    EARTH
    10x i think i 'll go for a crome
  13. Matts96HB
  14. efhondakid
    Akron-Canton, Ohio
    That is sig worthy right there.
  15. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    this thread actually made me laugh out loud. LoLLLL
  16. 97hatch
    97hatch ?
    Anderson IN
    well thats how they used to do it on old lt1s and the v6buick guys still do it some times
    i actually have a old LT1 vortec blower kit that came with a billet block that went in the charge pipe with 2 extra injectors in it
  17. intenseneal
    intenseneal New Member
    Yeah you need to tune that B16 badly. You are most likely running way lean. Get a Hondata S100 great tunning setup for boost and cheap S100 is only $200 plus tuning. Crome is ok but a Hondata will run the car soooo much better. Plus cost is around the same. I would look at getting some bigger injectors as well befre you tune. Get at least 310cc 450cc would be the best.
  18. Matts96HB
    What makes you think that Hondata will make the car run so much better?
  19. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    man am I glad someone dug up this gem of a thread... lol
  20. oyy0
    oyy0 Sleepy...
    you have now been quoted... great thread.
