B16a not accepting boost
just keep driving it. it just needs broken in. it might start making some noise but thats normal
yea nice laugh my crap of b16 is still untuned i installed a fifth injector as i sad i was gi\oing to do and now it's running on 7psi of boost and running great something like 13.4 @107.5mph 1/4 Mile on road 15" tires with no noises/breakdowns or something like you sad
tuners have to be tuners not jokers:disgust1:
I tought that this forums were serious but i changed my mind and sry i like my way of tuning 10x
run her till she blows captin it will happen show us the carnage pics when your done we would like to see them
Is this post serious, If so thats seriously old school 7psi no tune 5th injector , is it the early 90's again ???????????? Can't say i didn't run something similar back in the day most of the older racers started out with a setup like his . But we never stayed there!!!!! because stock tunning and FMU and 5th injector = Bang ..... just my 2 cents
you sir are a jackass
WOW. i was just poking around and im glad i did...... this thread is priceless! now im trying to decide which fucktard post to use as a sig......:confused: suggestions anyone? hahahaha:D
sorry for second post. but i must say my 5psi t25 fmu build worked flawlessly.
sure it will work, but for how long?
A FMU pinches down on the fuel return line adding x-ammount of pressure per pound of boost thus "solving" the leaning issue on a stock ECU.
Well what a FMU also dose is overloads your injectors and fuel pump, most stock fuel pumps fail after 100PSI and are stressed anything a tad over stock pressure.
also a FMU dosent retard your timing as you build boost, a FMU dosent accurately mix fuel and air, and it dosent protect you if you run lean and or rich (they both have their downs).
Stock ECU+ Stock injectors+ stock fuel pump+ FMU= Ka fucking boom!
Please tell me that your at the verry least your running a wide band O2 sensor?!
get it tuned and run your engine strong for years.
Yea , I had a wideband on it. Not sure if it was a fluke but everything ran just dandy. Maybe I got really lucky :)
I just retarded timing tiny bit and step colder plugs.
also threw a walbro 255 in it.
I ran it for months driving the absolute crap outta it lol! Then i did an engine swap.
i like how he didnt show his board. and yea you can see that he only trapped at 90. yea he got the teg off the line. whipty f***in sh*t. my stock b16 trapped at 92 with only a header. no intake or anything
