B16a Not Not A1 A2 Or A3
Discussion in 'HYBRID -> EG-EK / DC' started by pootSIracer, Mar 9, 2003.
  1. pootSIracer
    pootSIracer Member
    Scotia,NY
    I have a b16a that came from a junk yard I thinks its obd 1 but I could be wrong the only clue I have is that it has hydro tranny it also has obd 1 ditributer but I am not sure what the harness is oh well if you can help I would apreciate it
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    What car did it come out of?What is the serial number on the block?How do you know it is a OBD I distributor?
  3. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    Just look at the block if it says B16A, you know you have a 2nd gen B16A, if it says B16A2 you have a 99-00 Si motor, if it says B16A3, which it probably won't, you have a del sol VTEC motor.
  4. xj0hnx
    C.C.TX.
    What's the likeliness of finding a siR or siR II motor in a junkyard?
  5. TRuggiero_
    Winter Garbage, Fl
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
