b16a or b18c head
Discussion in 'Engine Building' started by ekPhred, Nov 11, 2002.
  1. ekPhred
    ekPhred Senior Member
    Hello everybody, I'm new to this forum and was wondering about which head would be better to put on a ls/vtec. I'm buidling one right now, slowly but surely... But, which head would be better to put on? If anybody has a ls/vtec equipped with a gsr head or either a b16 head please give me some input. I can either go either way with the head, just wondering if the heads really make a difference. Once again, thanx again for your input. Peace out guys! ;)
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I'm running a B20 with a B16 head. The power output between my engine and another identical setup but with a B18C1 head were the exact same- we both dyno'd at 185whp with the same bottom end, different heads. The B18C1 head will flow a little better than the B16 head when both have been heavily ported/polished. The B16A head flows just fine though, and is much easier to get. It's cheaper too! There are a lot more B16 heads out there than there are GSR heads.
  3. ekPhred
    Thanx for the reply Calesta, do you mind giving me a 1/4 time on your car? is your car an eg or ek? the car that i'm building the ls/vtec is an ek i recently purchased, thanx again for your input
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Get the head you can afford. I am running a B16 head, but my old roommate runs a GSR head, both motors run well and pull pretty hard.
  5. phunky.buddha
    I honestly don't have a decent 1/4 mile time... most of my runs are on the highway. Click on the link in my signature for info on my car. It's an EG, by the way.
  6. pissedoffsol
    there was a thread a while back on this.... the gsr flows minor points more in the midrange (probably due to the IAB on the IM) and then b16 had a few points at 7500+rpms.
    so yeah, get what you want really...
  7. ekPhred
    cool, thanx alot, all of ya'lls input is greatly appreciated, i'll let you guys know when I get all of my stuff put together, thanx again! B)
  8. ekPhred
    any other comments or suggestions
