Brian, don't push me.
To the original poster - that's great that you want to build a badass non-vtec, but you're really starting off from the wrong platform. Do you already have the B20A IN the car? If not, stop right there. The B20A isn't going to fit without a LOT of cutting/welding/custom fabrication. The B20A's mount completely different than any of the other B-series. In addition to that, because of their not-so-great rod/stroke ratio, they tend to be VERY unreliable above 7,000rpm. Back in the O.G. days, there was a handful of people who tried using the B20A crank in an LS block, and it had crazy midrange, but really wasn't good for anything other than towing a boat. Or a jet ski, maybe. In addition to all that, NOTHING from the B20A is interchangeable with other b-series stuff, except for the cam gears (and I'm not 100% sure about that). You're going to have a hell of a time finding parts, because the 85 Accord isn't usually at the top of the mass-produced aftermarket parts lists. AND you're gonna be stuck with the B20A transmission (as other B-series transmissions won't bolt up to the B20A block), which isn't exactly blessed with the best gearing.
So basically you're going to be stuck custom-fabbing just about EVERYTHING, which if you're on a limited budget, you aren't going to be able to do. I PROMISE you that you will be MUCH better off just picking up a B18B or B20B/Z from an Integra LS or a CRV and going from there. Either one of these would be a MUCH better choice for several reasons. Bolts directly up with stock mounts, a plethora of aftermarket support, and TONS of knowledge available online about them.
But, it's your call, man. I can pretty much guarantee you that you'll be much more successful in your 'eating of teh non-vtecs' with a B18B or B20Z/B than a B20A, but hey...it's your call.
