b16a-SiR Vacuum Routing
Discussion in 'HYBRID -> ED-EF / DA' started by Dark91zc, Jul 22, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    how do i setup the vacuum lines in a 90 crx dx with a b16a swap?? i did a search but nothingmatched what i was looking for :( thanks for the help
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    That should help you. Let me know if tehre are anymore tha you need.
  3. Dark91zc
    Corona,CA
    do you have any other vacuum line pics cause i have the map to charcoal canister line but i need the rest or should i take a pic
  4. B16CRX
    Greenville, SC
    That is all I have on my computer right now. I could go out and take another pic if you would be specific about what you want to see. The MAP sensor gets routed to teh TB anyways. For som ereason origianlly they have it Td into a line from teh TB to a block off spot under the right side of the factory MAP mounting block. LMK what you want to see a pic of and I'll get it.
  5. Dark91zc
    Corona,CA
    this should help for right now i am going to see what i have to do :)
  6. Dark91zc
    Corona,CA
    i need the rest of the vacuum lines :(i need fpr and the diaphram front and center on the intake manifold do you need pics
  7. B16CRX
    Greenville, SC
    Well, the FPR just goes straight to a tiny nipple on the back of the IM near where teh brake booster line goes. The other thing you are talkin about, I do not have on my IM, so I dont know where it goes.
  8. B16CRX
    Greenville, SC
    Actually, this may be what you are talkin about. Here is a crppy picture of what you are asking for I think. (old pic)
