So I've swapped the engine in. Axles, linkages, mounts, and ECU are a go. Here's where I'm stuck. Forgive me if this has been asked before but I've searched all over the site and can't find the answer. I'm using the B16A sir2 ECU with an adapter to the stock EK OBD2a wiring harness. How do I wire up the Vtec solenoid and the oil pressure plugs? Also, are there any other problems I will be encountering? Any insight will be greatly appreciated...
