B16A SiRI wiring help
snozepp147
i'm doing a swap for the first time and i got a jdm b16a sir1 to go into my 98 ex. i did get the obd2-obd1 conversion harness for the ecu's. my question is: with the ecu converted, will the wiring be very hard using my stock 98 ex harness to hook up to the b16a? does anyone know of any step by step wiring guides since this is my first swap and i have very little idea as to where to start/what to do with the wiring. thanks
swappin a b series motor into a civic is not as hard as it seems...if its ur first time i suggest u have both motors side by side and match up the plugs...if u want it to look cleaner, try not to cut and extend the wires, instead rip off the black stuff coverin the wires and try to pull some slack if u can..if not just cut, solder, and heatshrink..
