B16a stroker
Discussion in 'Engine Building' started by joesbadcrx, Sep 20, 2005.
  1. joesbadcrx
    joesbadcrx Senior Member
    I wanna know how you can make a B16a into a 1.8 stroker by using parts off the B18c1 gsr motors. do i have to use the b16a pistons or the gsr. I know you have to use the crank and rods but what else?
  2. jamesA
    Grab yourself a B18 crank and swap it. Or just buy a b18c.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Won't work without custom pistons and/or rods.
  4. DravenVX
    DravenVX Member
    I was gonna start a new thread about a stroker kit but i found this instead. I was wondering what kinda gains would one see from the Crowner Stroker kit for a B16A. It says that it will bump up displacement to 2.0, will that give some decent gains? Also are there any other companies that offer better kits for the same amount or a bit less cuz this kit is kinda pricy?
  5. formby
    formby learning in progress
    just buy an ls or crv block.....
  6. jamesA
    :doh: I thought about it after I posted it then I searched and forgot to post that.
  7. drpenguin
    drpenguin Senior Member
    Salem, Or
    Well what if we want to keep our b16. I would rather stroke my b16 then go ls/vtec i like my extra oil squirters or how ever you spell it. I was thinking of getting the golded eagle stroker kit personally
  8. joesbadcrx
    Well i found out that I can use my gsr crank and rods but do i use the b16a pistons or the gsr pistons. Help me out here on making this b16a a stroked b18
  9. phunky.buddha
    Nope, you can't do that either. You could use the GSR crank and rods, but that would require custom pistons to fit into the B16 without slamming the pistons into the head.
  10. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    why not just sleeve it to 84mm. about the same price as a stroker kit and can still rev the bitch to 11k lol
  11. joesbadcrx
    So i can run the b16a pistons with the gsr crank and rods and i'll be fine.
  12. 97CTR
    97CTR Senior Member
    NO you cannot run a gsr crank and rods and any stock piston in a b16. You would have to get pistons with a different wrist pin location.
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    How many times does everyone have to say "no"?...that combination wont work(GSR crank/rods+B16pistons in a B16) unless you get a deck plate thatll turn it into a B18 anyways or a Tech43 Piston Kit(requires rebore).
    I dont think the head will even bolt on if you tried that GSR crank/rod w/oem piston setup in the B16.
  14. reikoshea
    Dallas, TX
    rebore isnt that expensive...but i think i might be getting a discount since my friend owns an engine shop.
