mikey bottles
Prof. Bottles
allright so ive done quite a bit of searching and cant find anything that really matches my prob. i have an 88' Rex with a B16a OBD-0... the car seems to stumble under a load in all gears, from a stop or accelerating from a constant speed, usually at lower rpm's, and it will also stumble a tiny bit while cruising at a constant speed (and you can hear little 'pops' coming from the exhaust), and it only does it when the weather is warm!! i currently have no CEL on, rechecked the timing, and spark plug gaps today, replaced the distributor cap, and rotor this past tuesday, and the ignition wires are only about 6 or 7 months old, and do not show any signs of arcing or any of that. ive been as thorough as i can trying to describe the prob so hopefully someone here can help me out
