B16a swap crank no start
Jdm256
So I've been working on this car for awhile 89' Crx si I got a b16a with a td05 turbo from a donor car I rode in the car before I got the swap from the guy so I know it works, his car took some front end damage and couldn't afford to fix it however took no engine damage. Anyways I've got the engine in spark on cylinders 1 & 4 fuel pumps working timing I'm pretty sure is right but it only cranks no start D: this is my first swap so it's a little frustrating any help to point me in the right direction. More details I'm using a pw0 ecu that came with the car, good tune on it bought a new dizzy because I was getting an icm code at first fixed that.
Double check the plug wire order on the dsitribitor and make sure it's lined up centered so it's not advanced.
do you have the injectors that match the tune?
