So i just got done swapping in a b16a into my 91 dx crx. Everything works fine, car runs good. But the speedo doesn't work. It seems to all be hooked up correctly. I was just wondering if i needed to change it out. Because im using the one that i used with my d16 motor. I didn't know if there was a difference in the. Or maybe you guys know how to troubleshoot it. Thanks in advanced.
my b16 swap came with the digital vss. so i just took advantage and swapped in the ek cluster. if yours had a digital speedo then just plugging in the analog speedo cable wont work. it will just spit it out. believe me i tried. many times. look down at the vss and see if theres two bolt holes next to it, if not then your probly just not getting it in correctly.
