Alright guy's, im in a world of doo doo right now and I need some advice. I just had a b16a1 swapped into my 89 ef hatch and it's giving me some problems right now. I'm throwing these codes.
1. iacv
2.map
I recently replaced that map sensor but the code is still there and the car is still running really REALLY rich. My idle chugs at best and the whole car skips at idle. And i'm pretty sure my pcv valve has clogged. This is what happened, tell me what you think.
I was putting on a new tps which was bad also (problem solved) and when I tried to turn the car over to run it the thing died. It would turn over, crank and then die. Finally I remembered what happened to my buddy's 99 SI. So i pulled the hose leading to the intake manifold from the head and it ran fine, but with a high idle. After putting on a new pcv valve and re-running the hose, the problem still pursists. So as of right now, my car barely idles w/o feathering the gas, it gets around 10 miles to the gallon, and smokes really black.
One last thing which is still stumping me, there's no vtec. Could that be from the two codes that i'm throwing? I have no clue...please help!
1. iacv
2.map
