b16a swap to 91 dx
Discussion in 'HYBRID -> ED-EF / DA' started by j_max420, Apr 11, 2004.
  1. j_max420
    j_max420 Junior Member
    i am ordering a b16a engine swap for my 91 dx. is it a direct bolt in?
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    NO!!!!
    If your ordering a b16 get it from Steve at hmotorsonline.com. He is good. He is one of the only (and by far the most) reputable dealers of JDM engines in america.
    You NEED:
    mounts: $350 (GET HASPORT)
    Shift Linkage: $50-150 (GET HASPORT)
    Wiring Conversion from DPFI to MPFI (Dual Point Fuel Injection to Multi Point Fuel Injection): either buy a conversion harness for $150 or do it yourself.
    You'll also have to do some very minor frame alterations see hasport.com
    You should replace:
    The Clutch: $100-$350 (I recomend Excedy, but act also makes REALLY good performance clutches, but they're more expensive)
    Timing Belt: $75
    Water Pump: $40
    Spark Plugs and Wires (OEM HONDA ONLY): $50
    Distributor cap and rotor: $40
    For more info go to:
    http://b16a.honda-perf.org/index2.html
    http://www.geocities.com/teampimports/b16a.html
    http://www.phatwhippincrx.20m.com/custom.html
    http://tjshondas.20m.com/b16awire.html
    http://www.teirney.net/civic/EngineSwapPhotos.htm
  3. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    yeah check out those links and do a little searching around, its not hard, but make sure you know what your getting into...
