My engine B16a with 1000 miles,I took it apart just 1 day ago 1st because i had check compression after 1000 miles
and it read 150 across with std CTR pistons and OEM head gasket no resurface on the head,a couple days later my friends and I hear this noise coming fro my engine they say it sound like the rod bearings or main bearings and to my surprise #3 rod has little wear but can that really cause the noise sounded when it was running like something inside was hitting,Anyway my problem is how do i get new bearings how much do they cost and get the right one i dont see any colors after removing the rods and if i do see them where will i get that Fn plastigate THing......AHHHHHHHHH
2???? I want to forget the b16a and go with B20 but i want to know if most of my parts will fit the B20 flywheel clutch
and sensors stuff like the AND what does A b20 Short block run$$$ FOR....
