b16a transmission
90civicb16a
my car stock had a y1 lsd trans but it needs to be rebuilt so im trying to find out what other transmissions will fit my b16a???
ls has longer gear ratio you will get better MPH and more top end with a LS tran's but if you want to get down the 1320 fast then a B16 tran"s is the way to go, if you can find a 1.7 GSR trans that would be even better cause its between both of the other two.
