that's what I mean with how much money I have to spend ! , there is an honda tuning kit that cost 300$ and it comes with pretty much everything
YB , this socket right ?
S2 Aries 28-pin ZIF Socket [S2] - $10.00 : Moates.Net
I'm getting 263 whp on a similar setup with stock internals (except for a GSR cam) running a Precision T3/T4, SC-5027E, .63 A/R turbo. Expect for a dyno tuning session to be $400-$600 for about 3-4 hours of work.that 'box' is a catch can. it filters blow by gasses. your running boost, so lots of possibility for crankcase gas. maybe your rings arnt seated well anymore? i dont know exactly, but that's what the box does.
you have the exact same motor as me. and i'm going to boost my stock internals for a while really soon. if u dont mind, what kind of numbers did you make? How long did the tuning process take? How much did the tune cost? And how much fun is it? appriciated!
Necessary? No. But it will make more power.
nice ... I already installed the wiseco pistons, eagle rods , I would like to get something for the head !. I need some suggestions. BLANCO , after I put everything togheter , looked excellent , the car is running even faster and now it's great, but I don't know why , but on idle, i get a sound like if a bearing is damaged or something , or really bad adjustment on valves or different adjustment ? oil ? , I adjust them 0.006-0.007 INT -- 0.007-0.008 EXAHUST , after I accelerate a little bit it goes away, my question is .. is the timing has to be changed for those pistons( having in mind that the pistons has offset, the wrist pin is not in the center ) or something ? , cams ?, cam gears ? , and by the way, I put my SAFC for sale , Im getting CROME.
