I think I can't get better help than you people thank you very much , here in costa rica is hard for the people to help you , all the people that knows they keep all the information for themselves and they don't like to share anything.
I like more the TDC way , on UP and TDC with cyl 1 , ex of 2 and int of 3 , and turn the crank to backup TDC will have cyl 4 , ext of 3 and int of 2 , the reference is at TDC both ways , I think is the more accurate. The problem about getting the rotor as reference is that if I have the distributor not timed well , it will be as putting the straw/screwdriver , is not that accurate but with nice timed distributor is a nice reference too .
Blanco , doing that with tensioner will tight up well ? , the last time I loose the tensioner it got the belt loose really bad lol , I will try anyways I need to tight it up even if I have take everything apart ! , I adjusted the valve lash int 8 ext 10 and the ticky sound is less but I still have it, all lma's are loose at the begining and then they get tighter , I don't know if it was like that before my mechanic install the new pistons, but it doesn't look like the reason of the ticky , By the way i lost some torque in normal driving , racing I think I didn't lose that much or at all cause I still can feel nice power.
