I can't find any vacuum diagrams for a obd0 b16a in a 91 obdo0 integra. I keep finding crx diagrams but it looks different in the integra. Does anyone have the vacuum diagrams on how it's supposed to be in an integra?
Hope this helps, you should be able to use these two vacuum diagrams together to make sense of things. The biggest difference between the two is whether or not your intake manifold has the dashpot valve. Everything else in the vacuum diagrams appear nearly the same.
ok so i am having the same issue here with my b16 what the hell is a two way valve? it says the vapor canister connects to a two way valve what the hell is that?
