B16a
Discussion in 'Engine Building' started by TeamCivic, Apr 3, 2003.
  1. TeamCivic
    TeamCivic Junior Member
    hey guys,
    i was considering putting a si head and ecu on my vx hatch, but now i am leaning towards a B16A swap.. i have a few concerns though.
    first, is it a good idea to swap an older engine into my 92, i mean will it be reliable??
    second, since the B16A has a cable tranny, would i be better off getting another tranny from another b series engine like a ls or newer sir??
    i have herd good and bad things about this swap. Your 2 cents would be appreciated..
    thanks,
    Blair..
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The cost of getting a hydraulic tranny and the ECU distributor,injectors make just getting the right motor in the first place a better idea.It comes out to about the same.
  3. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    :werd: Just get an SiR II motor. The extra 500 bucks is worth the huge headache you will avoid. And you get an extra 10 hp.
  4. E_SolSi
  5. luVTEC
    luVTEC Senior Member
    either get the B16a SIR II or go with ls B18b, stay with OBD1 engines. :D , otherwise you'll be fucking around with wiring to much.
