B16A
pwrfulz28
JUST FINISHED A B16A ENGINE IN A 89' CRX. STARTS FINE IDLES FINE BUT CUTS OUT AT 3200 RPMS. CAN NOT GET ANY CODES FROM THE ECU CAUSE THE LIGHT DOES NOT BLINK, IT STAY ON ALL THE TIME . I THINK IT MY BE VTEC RELATED BUT CAN FIND ANYTHING WRONG. IF ANYONE HAS RUN INTO THIS PROBLEM AND KNOWS THE TRICK, I WOULD BE THANKFUL FOR THE INFO.
THANKS AGAIN, KEVIN
OBD0 ECU pr3 not blinking = code 0 = limpmode= ECU fried
Yeah thats what the manual sais for code 0 but i've seen wiring not done properly and code 0 came out even though the ecu was good.
It'll be a good idea to try another ecu if possible. If not, make sure every single wire is making proper conection.
Check Pins B10 and B12 "Crank angle sensor" if not hooked up properly or not receiving signal it may give you the simptoms that you have.
Get wih me on AIM i'll try to help you some more..... OldSchoolSwap
