B16A
Discussion in 'General Tech and Maintenance' started by pwrfulz28, Aug 16, 2003.
Thread Status:
Not open for further replies.
  1. pwrfulz28
    pwrfulz28 Junior Member
    JUST FINISHED A B16A ENGINE SWAP ON A 89' CRX. IT STARTS FINE AND IDLES FINE BUT CUTS OUT AND BUCKS AT 3200 RPMS. I CAN NOT GET ANY CODES FROM THE ECU CAUSE THE LED LIGHT STAYS ON ALL THE TIME AND DOES NOT BLINK. I THINK IT MAY BE VTEC RELATED BUT CAN NOT FIND ANYTHING WRONG. IF ANYONE HAS RUN INTO THIS PROBLEM AND KNOWS THE TRICK, I WOULD BE THANKFUL.
    THANKS AGAIN, KEVIN
  2. kingwilly
    kingwilly Senior Member
    arizona
    i replied to your post in the ecu section..check that out and after you check or do those things then unplug the negative cable on your battery wait a few seconds then put it back on that should reset your ecu
  3. Loco Honkey
    Loco Honkey Banned
    Don't make me say it again.
  4. kingwilly
    arizona
  5. Dman1100
    Dman1100 Senior Member
    Des Moines IA
    did you jump the connector?
  6. legutki
    legutki Senior Member
    I had the same problem after my swap. If its a OBD 0 pr3 the light not blinking means its a code 0 and its in limp mode and your ecu is bad. get a new one and youll be good to go. It also might mean that if you chipped your ECU and got it reprogrammed that they did a bad job and ruined your ECU.
  7. phunky.buddha
    Dallas / Fort Worth, TX
    Please refer to our FAQ. There is no need to post your topic more than once.
    This topic has been closed by a moderator. Please continue your question in the other thread that you started.
    Thanks, Moderating Team
    :locked2:
  8. phunky.buddha
    :locked2:
  9. phunky.buddha
    :locked2:
Thread Status:
