B16a
Discussion in 'HYBRID -> EG-EK / DC' started by stud4u2c17, Feb 26, 2003.
  1. stud4u2c17
    stud4u2c17 Senior Member
    Okay general concept....
    ZC Swap is around 1200 for everything including installation
    B16a- bout 2000 for everything
    is 800 really worth 30 hp??
    I know they might be a little outragious priced for the ZC but i dont half ass on anything (installin my self)
    well thanks for your replys! :D
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Is it worth it to YOU? That's the real question. This is going into an 88-91 Civic, right? If that $2000 is the full "drive out" price on a B16 swap, that's pretty good.
  3. E_SolSi
    :withstupid:
  4. sportlinecrx
    sportlinecrx Banned
    here are some facts to consider:
    PROS:
    1) The ZC engine weighs about 75lbs less than a B16, which means the actual performance gained based on power/weight ratio is greater than what the horsepower numbers alone dictate.
    2) i have read that alot of ZCs put out more horsepower than they were rated at by the factory. there is a website that mentions this. i'll try to find it for u.
    3) price
    CONS:
    1) if you live in cali, all JDM engines are illegal (will be an instant fail at smog check time). and the only smog legal B16 is the B16A2 out of a 99-2000 civic si...and it has to be outfitted with california smog equipment.
    2) the ZC uses parts from about 5 different honda engines, making it confusing when u want to add on to it.
    3) there is so much more aftermarket support for B16's. in fact, B16's might have the record for aftermarket products available.
  5. sportlinecrx
    sportlinecrx Banned
    check out this ZC page. its got tons of great info although it wasnt the one i was looking for. look at the parts chart (lower on page) and u can see how many different engines you'll need parts from when you have to replace something.
    http://www.88-crx.com/ZC_Page/ZC%20Swap.htm#ZC Specs
  6. simonc
    simonc Member
    There's one ultimate thing which makes a B16a far superior to a ZC, in a word (or acronym!) VTEC.
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Well,you could think about this,When people are buying bolt ons such as I/H/E and easily spending $1000+ for gains that might equate to around 8-25hp,sounds like 30-40 actual horsepower for $800 sounds better and better.
  8. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    Correction: JDM engines are legal in California, they just need to have a USDM counterpart and all the smog equpiment, that the USDM counter part had. The ZC is illegal, because there was not a usdm ZC. And the USDM counterparts were in the B16 the B16A3 (Del Sol VTEC) and the B16A2 (99-00si).
  9. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    Some of the old tegs have USDM ZC's in them.. right?
  10. xj0hnx
    C.C.TX.
    Yes,but I think they were still stamped as D series.
  11. Domeskilla
    Fort Wayne, IN
    A ZC is a d-series engine. :)
  12. xj0hnx
    C.C.TX.
    I know but over here we have the same motors actually stamped with ZC is all I'm saying.
  13. Domeskilla
    Fort Wayne, IN
    Ah. Okay. I dont know shit about them. I just knew they were considered a d-series motor.
