B16a1 compression
Discussion in 'General Tech and Maintenance' started by Drunkencat, Sep 17, 2008.
  1. Drunkencat
    Drunkencat New Member
    I am getting ready to buy a B16a1 engine swap and I had the guy send me the compression and leak down numbers from japan. The leak down is at 9% and the compression is 205 +/- 5 or 10 per cylinder. Are these numbers good? Or should I look elsewhere? Thx
  2. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    205 psi? I thought the compression was 186 psi for a B16a2? But ya seem likes your compression is great but i have no idea about the leak down test.
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    9% leakdown is pretty good.... 5-10% is normal for a good running engine. some engines may run well with up to 20%.
  4. Drunkencat
    Cool. I'll have to buy it. Also, what is the tranny code for LSD?
