B16a1 In 92-95 Ex
Discussion in 'HYBRID -> EG-EK / DC' started by slowciv1, Apr 24, 2003.
  1. slowciv1
    slowciv1 Senior Member
    AZ
    I have an ex and was wondering if i should use the ex ecu and chip it for b16 or use the jdm b16 ecu obd0? Which would be best?
  2. E_SolSi
    first of all you shouldnt use the B16A1
    get an SiR-II (OBD-1)
    it will work with your car withough the headaches of trying to make an OBD-0 cable trannied engine work
    use a chipped P28 or a P30
    an OBD-0 ECU will not plug into your car without some serious fucking with
  3. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    i would say go with the P30, check out Pills' page: http://www.hondaswap.com/~pills/. he dynoed his car with a chipped P28 and a stock P30. check out his results.
