b16a1 in Delsol
4doorb16
I have a jdm 1stgen b16 and want to put it in my 95 Delsol.What would I need to make it work?
your best bet would be to sell it and get the correct B16 (OBD-1)
yeah, get the OBD 1 version B16, ENTIRE THING- Block, head,distributor, tranny. Other than that you will need, axels, shift linkage, ECU, Wiring harness-depends, and run a knock sensor. It should be the easiest swap, except if you choose to get the wrong OBD, then you run into a whole shit load of wiring harness problems.
Darin
you need a place racing tranny mount for that cable series tranny to work. I would do what E said.
