b16a1 into a ef sedan
ABK
What would my shopping list for swapping b16a1 into a ef sedan (manual). I mean like everything.
And does anybody have a swap article somewhere about it, too?
I did some swaps in the EGs but nothing in EFs. I'm pretty sure it will little more complex because I will prolly end up using parts from like 4 different cars.
Thanks
No Shift linkage comes with the motor, so either get a (i think) 90-93 integra one and modify it. You don't need they're wiring, altho if your car is a DX, you have to convert from DPFI to MPFI, which is a BIG bitch.
no its not, if you can't do the wiring you shouldn't be doing the swap, theres plenty of instructions out there, and it is 90-93 DA integra for the linkage
