B16A2 complete swap on Honda City sx8
Discussion in 'Other Vehicle Discussions' started by HondaMru, Jun 21, 2012.
  1. HondaMru
    HondaMru New Member
    Hi there
    Am new here .. Want sharing opinions for my projects B16A2 complete engine swapping on a Honda city sx8 . Is there lot of modification ... best way for installation ... any opinions etc ...
    Thanks for your reply.
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    What year? Model? Your mechanical abilities?
  3. HondaMru
    HondaMru New Member
    Thanks for reply...
    Its a Honda City yr 00 , 1.5L .. body style 4 doors.... Transmission manual .. from Thailand country.The curb weight is 940-985kg .. I think its the lightest body among honda models but am wondering how much horsepower the body can handle !! Plan to setup stabilizers Front + Rear .
    For braking .. original drum rear brake ! conversion rear disc may not be applied for this model . Plan to workout better front brake system first to see the result.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Isn't the City just another version of the Civic? D15B and D13B's, so if they kept the family tree rooted it should be a fairly easy swap.
  5. HondaMru
    HondaMru New Member
    yeah .. it related honda civic ( sixth generation) . Do you think the halfshaft B16 will be fitted or modification need to be done ?
  6. CAFROG
    NOR-CAL
    If its like a 2000 Civic Sedan....swapping a B16A2 ain't that hard. Read on EK swaps and you'll find the info.
  7. xj0hnx
    C.C.TX.
    You will definitely need the B16A halfshafts
  8. HondaMru
    HondaMru New Member
    Hope so .. am worry about due the body was made from Thailand , not from Japan . Thanks for your advice .
  9. HondaMru
    HondaMru New Member
    what do you think about the braking system .. front disc + rear drum .. any advice ??
  10. HondaMru
    HondaMru New Member
    Sure .. I will get a complete engine swap . Thanks for your advice.
  11. CAFROG
    NOR-CAL
    My advise...brakes are fine for now. I tackle one project at a time :wink:
    Is the car RHD or LHD? Where are you going to source the swap? Will it be the same side drive (steering wheel on same side)??
    Also....please tell us the motor that's in it now. Says it on the engine block where it connects to trans....right near the radiator. Like d16z6 or d15b. I need to know if it's VTEC already.
  12. HondaMru
    HondaMru New Member
    Thanks you ...I got the same advice for the brakes . I was a bit confusing about rear dics vs drum .. but the honda city rear brake system is independent from the front ( i.e rotor only ) .. brakes are fine for now ;)
    The car is RHD .. The Engine B16 is RHD side drive too.
    The original engine d15b is non-vtec .. engine block connect to trans .. right near the radiator . I mind the b16 block will fit same position brackets . isn't it ?
  13. CAFROG
    NOR-CAL
    You need (at least) the rear trans mount off the B16.....all the other D-Series mounts will work.
    Once you got the B-Series rear trans mount........motor, trans, axles, and shift linkage will mount directly with no problems.
    The motor is OBD2 (if it's a B16A2). Have you confirmed this?
    What is the code on the B16A2 ECU?
    If chassis and swap are OBD2....I believe you just use the B16A2 engine harness/ECU.....and take the old harness/ECU out. The engine harnesses should be one piece. Directly off sensors straight to the ECU
  14. HondaMru
    HondaMru New Member
    Thanks you for the tip .. I will check for the rear trans mount to be included ;)
    B16A engine second generation OBD 1 ECU code P30 with trans hydraulic
    My chassis is OBD 1 P3s. I will check the engine harnesses to be in one piece . I attach a pic of both ecu . what do you think about ?[​IMG]
  15. HondaMru
    HondaMru New Member
    My project plans for the B16A engine are daily driven , street racing 400m and 190 + HP.
    First Phase:
    The B16 engine will be already chipped ecu , 4-2-1 header and all stock parts engine.
    Any suggestions with low cost budget if possible ..???
  16. HondaMru
    HondaMru New Member
    The chassis is also cable trans and conversion is needed for B16 hydraulic trans.. Any advice ?
  17. CAFROG
    NOR-CAL
    Its a 2000 Civic with a cable trans?? And it's OBD1?? No Civic in the states or Japan are anything like that. They are OBD2B with hydraulic transmissions.
    ECU's are different OBD.....at least they don't look like the plugs are similar.
    I'm really confused about your swap now lol. You should be OBD2 and I've never ever seen a B16A2 swap that came from the factory with a P30 ECU. B16A (SiR 2) and B16A3 (USDM Del Sol VTEC B16A3) ran that P30.
    Only Civics that are cable transmissions are OBD0 (pre-1992) cars.
  18. HondaMru
    HondaMru New Member
    I said in my early post the chassis is Honda City SX8 model 1.5L non vtec year 00 made from Thailand , not civic . It has cable transmission .
    Its a JDM B16A second generation. Check that link specs .
    Honda B engine - Wikipedia, the free encyclopedia
  19. CAFROG
    NOR-CAL
    Tha is for the Wiki link lol. I've owned that swap :wink: it's called SiR II OBD1 with hydro trans.....I know.
    Not sure but I think you perceived my last post incorrectly. If You read again.....iit explains how weird that car is compared to ever single 2000 Civic I've ever seen or read about. I'm guessing India was way behind and they had cable transmissions and onboard diagnostics that are 5+ years older than any USDM or JDM civic of the same year
    The whole situation has me curious and baffled.
    If it is truly a OBD1 car....Then you just have to run VTEC solenoid, VTEC oil pressure and Knock Sensor (google and you'll learn more) from the B16A (SiR II is NOT a B16A2) engine harness to the plugs where the ECU connects. Ffsquad.net has good info on the process.
    And a hydro trans can be put in a cable car with that adapter. Mixed reviews on its functionality. I (personally) would get a rebuilt SiR I cable trans (88-91 Civic).....no need for a adapter. But if funds are tight...get the conversion adapter and deal with it.
  20. phunky.buddha
    Dallas / Fort Worth, TX
    According to the never accurate Wikipedia the SX8 City was based on the EF Civic platform- which means the 88-91 Civic in the US market. That would explain the cable clutch transmission.
    CAFROG, as far as OBD revisions and "being behind," every country has their own regulations on what kinds of emissions controls a car must have for a certain model year- so every country's standards will be slightly different based on the laws they have regarding their cars.
