We have a B16A2 engine in my brothers coupe. The ECU appears faulty. We have a "Type R" (B16B) ecu. Will the B16A2 run correctly with this ecu? Ther barcode on the side of it reads: 37820-PCT-003-1115-102480.
As long as you have the same OBD type as your engine and chassis any B-Series ECU should work. When I had an LS motor non-VTEC, I was troubleshooting the current ECU cause my car wouldn't start. I plugged in my buds OBD I J-spec B16A ECU and my car started right up. Point of this story is my first sentence.
