B16A2 Engine/Head Identification??
Discussion in 'HYBRID -> EG-EK / DC' started by Som1Dies2Nite, Apr 29, 2006.
  1. Som1Dies2Nite
    Som1Dies2Nite Member
    My brother bought a B16A2, Is it JDM? So say it is and others say its not.
    What is the original head thats on a b16a2? PR3? or is it something else?
  2. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    As far as I know, the b16a2 is a USDM engine.
  3. Som1Dies2Nite
    When I do a search I also find thats its a JDM. The 1st gen B16 is b16a so what could you call a 2nd gen b16a? I need to know the head as well.
  4. jamesA
    Looking at the engine with the distributor cap on your left side, from the distributor cap where it connects to the head itself, look straight down until you find a stamp on the block itself. If it says b16a2 with a green vin stamp right near that, it's a USDM b16a2 from a 99-00 Civic Si.
    b16a2 is ONLY in the USDM market (and Canada). I honestly have no idea what the name of the a2 head is... it's 3 am and I can't think of the name.
  5. Som1Dies2Nite
    My brother traded rims(twisties) for a PR3-4 head that has an TD87U dizzy. Is that an itr head or just b16a with and r dizzy? Also the guy told him he just threw in skunk2 cams? The cams look new but Is there way to tell? Any identification so he knows exactly what he has?
  6. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    I think the R head is labeled pr3 as well as all the b16s
  7. reikoshea
    Dallas, TX
    im quite sure you are right as well. B16a2 is a USDM engine to clarify.
  8. 98bswap
    98bswap Junior Member
    It is a PR3-2
  9. Som1Dies2Nite
    What about the skunk2 cams? Where is the id?
  10. schemo24
    schemo24 New Member
    They are also in Europe.......................
    B16A2
    • VTEC
      • 1992-2000 Honda Civic EDM VTi (EG & EK)
        • Displacement: 1595 cm³
        • Compression: 10.2:1
        • Power: 158 hp @ 7600 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
        • Transmission: Y21
      • 1999-2000 Honda Civic Si (EM1)
        • Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: Y21 S4C
      • 1996-1997 Honda Del Sol VTEC (EG)
        • Compression: 10.4:1
        • Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
        • Transmission: Y21
  11. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Correct.
    If the block says B16A2 it is either a USDM 99-00 Si motor, or a euro. Possibily from eastern block, or Africa....but I doubt it.
  12. JDM_EK9R
    JDM_EK9R all motor
    central, NJ
    africa? lmao ... b16a2 is USDM ONLY. comes in 99-00 honda civic si. the head is a pr3 which IS the same casting as a type-r head minus the mild hand port and beefier valve-train + cams. DONE DEAL.
