b16a2 header=b18c1 header
Discussion in 'HYBRID -> EG-EK / DC' started by civicsi1415, Jul 1, 2003.
  1. civicsi1415
    civicsi1415 Junior Member
    I was wondering if any of you guys know if the b16a2 header and the b18c1 header for the civic si and gsr are the same....I was wondering because skunk2 sells a header for the acure integra gsr but not for the b16 and i thought they were the same...... maybe i smoked to much before i wrote this.....hahaha
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    b18c header will fit but not vice versa, the gsr header will be lower though towards the ground.
  3. civicsi1415
    so the gsr header will fit the b16 but the b16 header wont fit the gsr.....did i get that right. would you know by any chance how much lower it is???
  4. phunky.buddha
    Dallas / Fort Worth, TX
    I don't know exactly how much lower... but the B16 header will rub on the B18C's oil pan. It'll work, but it'll touch. Use that to gauge how much difference there is. If you find out the differences in deck height between the B16A and the B18C, I'm sure the difference will be pretty close to that number.
  5. vtecsir1
    Orlando, FL
    we tryed to put a friends 4-1 dc b16 header on his new swap (b18c) would not fit, not even close.
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    theres you answer, 1.6header won't fit the 1.8
    Milan
