yep i caught that just now, im still not retracting my statement thoughoic.
LS_vtec you are a very smart tuner and I never once said if you look back that you don't know what your talking about I'm just saying my setup will work, It might not be the best be the guy never asked for the best turbo setup, I just gave him my setup. BTW I have more mods than stated I just don't want some bigass list under my name. I have a K*&N intake with an AEM dryflow filter, upgraded brembo rotors drilled and slotted with hps pads and earl's lines, no cat converter, sleeper muffler(looks stock but is just a straight pipe with a magnaflow resonator as my muffler through 2.5 pipes, I have a low temp thermostat and a ricer autometer tach that came with the car that I'm going to switch out for an Si guage console. I have acouple other bolt-ons that I'm not going to list, I'm not that modified but the car still pulls. Not like my SRT-4 tho, I run 12.2's all day in that beastNow that I look at it, it makes sense.. His headline is in Gold, everything underneath are the modifications.
I wouldn't consider myself a tuner, I am just a technician.
Finally, that was exactly what I was thinking. Good looking out bro.This is crazy, I had to register on this garbage forum just to add my 2 cents. I search for help on swaps, come across this site, THOUGHT (<--past tense) it might be helpful. Schleht was tryin to help the dude out, and somehow or another ls vtec just attacks the man?? Cmon dude, I dont give a shit if your certified, the guy was putting an opinion out there, thats not wrong. Not everything has to be done by your specs ls vtec. Damn, let the forum help people, but it really seems like you have low self esteem and try to be a know-it-all and show that by attacking peoples opinions. THIS IS A GARBAGE FORUM! By the way, I think its cute how you got your lil groupies!! wink wink hondadude.
Ok here's how it goes... i have a b16a2 swap into a 93 civic hatch with a gsr tranny... i want to go fast and be able to get there quickly. i know i need a turbo but what else should i be looking @ geting?
Nah im not one of his buddies brutal, I wouldnt drive srt-4. And im pretty sure this thread was about b16 help right? Well thats what the topic said, and yea im interested in a swap and a b16 is a common swap right? Wheres the help with the b16? NOT HERE! The moderators should slap the shit outta you and ls vtec for bieng such dicks. Honda isnt everybodys life, i understand if your gonna be turnin a wrench for the rest of your life, but for most of us its just a hobby.
Meth injection will keep the egt's safe no matter what, and you only set it to kick in at high boost...and the ECU will help you gain traction by more percisely tuning the vechicles timing, boost, fuel/air ratios and injector pulses...better tune = more traction.
damn son you dont need half that stuff to hit a easy 300 whp. stay away from any vafc hacks and always use oem honda ignition. im not going to pick apart that list it would take me to long, just look at my sig and understand that you dont even need most the stuff i have to hit 300 whp and im doing it with a SOHC and its my daily driver, its reliable, gets 30+ mpg and gets beat down the track every weekend pass after pass. with a DOHC you will hit 300 whp allot easier then i did. and 300 is plenty for most any one. if you go to www.evans-tuning.com and look around you will learn allot, the dyno librarys list what different combos made and whats all doen to each. good luckChoose your Turbo size/setup and get these supporting modifications:
BuddyClub .2mm Turbo Head Gasket - $172.26
CoolingMist Meth/Water Injection Kit - $350.00
Walbro Performance 255lph Fuel Pump - $94.95
Russel Stainless Steel Fuel Line Kit - $21.83
AEM Red High Volume Fuel Rail - $134.95
RCengineering 440cc Fuel Injectors - $314.95
Aeromotive Boost Dependant FPR - $165.55
PowerRevRacing 0-100psi Fuel Pressure Guage - $30.00
Apexi Tru-Boost Electronic Controller/Guage - $279.99
MSD Boost Timing Controller - $228.99
MSD Complete Iginiton Set - $278.99
Apexi S-AFC Neo Fuel/Vtec Controller - $279.95
AEM Eugo Digital Wideband O2 Guage - $239.00
The head gasket will lower your compression, the meth injection cools combustion down and prevents knock @ higher boost, the walbro fuel pump supplies fuel through the RC injectors to the AEM fuel rail controled by the aeromotive boost dependant fuel pressure regulator and a fuel pressure guage rigged to the fAEM fuel rail so you can set the static fuel pressure precisely. You tune your fuel maps with the APEXI S-afc Neo(I chose this piggyback for you because of it's ease of use, a more complete ECU type programmer will help you gain traction and can be set more accuratly) the aem eugo will give you an accurate air/fuel ratio. Your going to need one step colder spark plugs and an upgrade msd ignition system and use the MSD boost timing controller to set the advance on the ignition firing and finally, use the boost controller to set your spike and hold boost settings. Good luck
