Hey guys,
Im running into a bit of a bit of a, what seems like electrical problem.. Here's the beginning.
Engine was Slipping like crazy(worn out flywheel), and then one day the battery died completely, so I took it into the garage.. took apart the tranny using the G3 Clutch change DIY Guide, which was amazing. Changed CLutch/Pressure Plate/Flywheel Resurfaced. Everything grips, engaged, etc properly.
Now for the problem..
The CEL is NOT on.
The Batter light IS on.
When the battery is fully charged, Battery light is still on. Disconnected Negative Cable, Car runs. Disconnected Positive Cable, Car runs. The car actually runs Brighter and more steady when the battery positive cable is not plugged in.
Also, If I have the battery fully charged at night, when I wake up in the morning it is COMPLETELY dead, no juice at all. (No lights on when I leave the vehicle, no noises, nothing. And Ive tried 3 batteries, all which work in other vehicles.
Also, since I changed the clutch(Rebolted tranny), car was running fine with the battery light for an hour or so, parked it fine, then it wouldnt turn over. Changed the Fuel Filter, and it turned over right away but now when it drives, but when no RPM just dies out right away, but I can turn it back over, it feels weak but it still turns.
Checked the grounds(Both of them from Tranny to chassis and they seem fine).
Any help/Suggestions/Any troubleshooting you may have me done would be greatly apprecaited.
Thanks guys!!!!
~Josh
The CEL is NOT on.
Thanks guys!!!!
~Josh
