B16a2 In 94 Hb
Discussion in 'ECU's, Electronics, and Tuning' started by wisemansoji, Mar 4, 2003.
  1. wisemansoji
    wisemansoji Senior Member
    I droped a b16a2 in my 94 cx hb and I used both wireing harnesses but my speedo isn't working the tack works but the speed doesn't register, everything else works fine. Any sugestions on how to fix this.....oh yah the engine light also stays on would this have somthin to do with the speedo.
  2. civicSiR1
    civicSiR1 Senior Member
    check out the speed sensor....
  3. possessed imports
    possessed imports Banned
    check the code ur ecu is giving u
  4. sirkurtius
    sirkurtius Member
    toronto canada
    check the code, it may have something to do with the speedo. see if your speed sensor is plugged in?
