A Acepryus New Member Jun 15, 2009 #1 What all does it take to get the motor in? I'm not sure what it takes to get the EJ8 engine bay compatible with the EM1.
N namoper New Member Jun 17, 2009 #2 The motor will drop in no probs. You need to have the b series mounts for it and job done. The loom from your ej8 will need to be used on the b series. You'll need to move a couple sensors and change a few plugs on it though.
A Acepryus New Member Jun 17, 2009 #3 Who makes some mounts? Hasport doesn't have any. I'm also tuning with a hondata s200.
BrutalB83 Brutal Moderator Moderator VIP Jun 17, 2009 #4 Acepryus said: Who makes some mounts? Hasport doesn't have any. Click to expand... Hasport has them. Look harder...
T ThatNinja New Member Jun 17, 2009 #5 I believe its not custom mounts you need, just different OEM ones.
BrutalB83 Brutal Moderator Moderator VIP Jun 17, 2009 #6 ThatNinja said: I believe its not custom mounts you need, just different OEM ones. Click to expand... That's correct. Hasport's stock replacement mounts should work fine...
