B16a2 in a Sol from Ardperformance.com?
Discussion in 'HYBRID -> EG-EK / DC' started by hondamidnighter, Nov 22, 2003.
  1. hondamidnighter
    hondamidnighter Senior Member
    Can anybody give me iformation about this engine? Would this engine go in my del sol with no problesm???Or it has to be b16a3? :huh:
  2. civic15.8
    civic15.8 Senior Member
    alabama
    yes the b16a2 is what you need but you will have to worry about the knocksensor wire and the vtec wires if you dont already have vtec
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    all del sol's even "S's" are pre wired for vtec (kinda like how all 92 civics are)
    Yes you will still have to wire up a knock sensor, unless you run a chipped p28 ecu (does not look for a knock sensor) also, what ever route you go, use an obd1 ECU.
  4. civic15.8
    alabama
    i stand corrected
