b16a2 into 91 crx si
crxsk8er
Member
i need to kno everything im going to have to do i have the ecu and a b16 cable tranny i need to kno what wiring im goign to have to do and what im going to have to buy
if anyone has a link to a site with info could you let me kno
im doing the swap soon and need it running quick
Thanks
-Chris-
You'll need
1. Mounts (i used Hasport)
2. Shift linkage from Hasport or a modified Tegs
3. 88-91 Sir axles and inter or 90-93 Teg axels and inter.
4. 93 teg upper and lower radiator hoses (i think you can use the 90-93)
If your going OBD-1 You need to get a OBD-0 to OBD-1 Harness, much easier and worth the money. I did it the hard way. And the OBD-1 engine harness. You'll have to use the injectors and plugs, distributor plugs, and o2 sensor and plugs. and splice it in to your si harness.
If you are going OBD-0 then you'll need a jumper harness to hook up the vtec and an OBD-0 Dist, ECU for a B16a.
I might have left some things out. Will post more if i remember anything else.
