b16a2 into 92 SI
sleepyzze110
my cousin has a b16a2 from his 00 SI that he taken out recently to swap in his b18c5
my question, what is needed and what needs to be done in order to swap this into a 92 civic SI hatchback, would the engine and tranny bolt right in? what about ECU and wiring and stuff
and i can also keep my jdm guage cluster right?
here are the mounts that you will both need
https://hondaswap.com/forums/uploads/10..._1091111790.jpg
you need to either get an OBD I ecu designed to run the b16 (P30), or else a P28 that is chipped to run the b16a
you will need to wire vtec if your car is not so equipped, and you will also need to wire a knock sensor if you are using the P30 ecu
yes you can keep your JDM cluster
this topic has been covered about 19 million times, here and everywhere else on the web- A basic search on google will bring you pictures, step by stpe directions, etc
