R2R Racing
Ok we are about to drop this b16a2 out of an 2000 civic si into a 93 del sol si.
Here is what I got so far.
Parts included in swap. Motor, trany, ECU, motor harnes, axels
What I have thought of so far.
The del sol has hydraulic trany so we should not have to convert from cable.
We have a shift linkage from a b16 del sol.
We have a rear motor mount from a 97 GSR.
I think one of the exhaust systems we have will work for the secondary O2 if not I will just weld up a test pipe.
My Questions
1. Will the OBD2b ecu from the B16a2 work with the body harness. Specifically will the two plugs, other than the engine harness plug, plug in and run the dash cluster ect.
2. Will the B16a2 axels work with the 93 del sol.
3. Can anyone think of anything I am missing.
P.S. This is my first Honda Swap. LOL But many more to come.
My Questions
