b16a2 into a 89 crx cel / mil wiring. No injector pulse (this has been fun)
Discussion in 'HYBRID -> ED-EF / DA' started by tweeder, Apr 27, 2007.
  1. tweeder
    tweeder Junior Member
    Ok so I'm doing this swap for a friend of mine. I have been playing and researching for three weeks. Here is the story...
    obd0 harness
    obd1 ecu (p28 chipped by phearable)
    obd2 engine
    Converted the 1 ecu to 0 harness using a sub/conversion harness
    Converted the 0 harness to 2 connectors chopping up the 2s harness
    I can not get a signal to fire the injectors, the fuel pressure is there.
    The injectors have been tested and work. 12 ohms across each one give or take .2 so I don't need the resistor pack.
    The wiring has been tested all the way back to the ecu to fire the injectors manually plugging a wiring into the harness that directly plugs into the ecu plug and then taking that to ground. This will fire each injector with the key set to run with the fuel rail pointing out to the atmosphere.
    Have tested ckp cyp tdc on distributor to the best of my ability.
    And I do have spark on the spark plugs.
    So a few questions,
    What generates injector pulse width?
    Which pins on the ecu do I need to jump to pull a code? (I think the colors are brown and black but which pins are they? Or are the colors brown and light blue [both data link connectors])
    And which wire outputs to the actual dash light?
    Can this wire connect to chassis ground for its ground?
  2. tomogchi
    tomogchi New Member
    Being as you checked everything, Take a wire (10 inches or so, really doesnt need to be that long) and run it from the thermastat housing to the ground on the transmission.
    -if that doesnt help ignore my post. Im not really with it so i really skimmed through it.
  3. tweeder
  4. Walterronny
    Walterronny New Member
    is it tuned? try with another ecu..
  5. tweeder
    I have tried the one i mentioned above plus a stock p28 and the stock crx obd0 ecu for an si d16a6.
  6. Walterronny
    well, for i know , pulse with is generated by ecu and i think it has to do with main relay. i assume you means are using harness conversion OBD0-1 , right?
  7. 93vicb16a2
    93vicb16a2 WHATS CRACKIN??
    bfe
    did u leave the injector resister plug open??
    if so i had 2 connect all 5 wires together when i used obd1 injectors
  8. hondasniper
    hondasniper Engine Builder
    did you try a pr3 or pw0?? (find a friend that has a b16a obd0 swap and borrow his ecu) if you just disconnected the injector resistor box and failed to jump it, your injectors won't work.
  9. 93vicb16a2
    bfe
    thats what i did
  10. tweeder
    I have the five wires jumped together. I don't have access to a b16a ecu, but I do have the stock pm6 that we tried with no luck... keep the ideas flowin please...
  11. golfersteve
    golfersteve New Member
    did you ever figure out
    ever figure out i am having the same problem
