B16a2 into a 99 civic EX
Discussion in 'Civic and del Sol - EG and EK' started by pimpson88, Oct 7, 2006.
  1. pimpson88
    pimpson88 The Civic Guy
    Stanwood, WA
    So i bought a 99 civic ex with a b16a2 engine swap. I am having a lot of electrical problems and was wondering what i need to look for and steps in fixing it. All that i really know is that its not idleing right. It will run but i have to keep my foot on the gas otherwise it will die. Also the vtec wont kick in till about 6000rpm. I know part of the problem is there is a leak in injector #4 and when checking engine codes the iec and o2 sensor came up as there were problems. Also is there anything that i might have to wire in for the vtec? Any help is appreciated. Thankyou
  2. reikoshea
    Dallas, TX
    what kind of ecu are you using?
    the o2 sensor will cause the idle problem as well.
  3. pimpson88
    Stanwood, WA
    Im not sure what ecu is in there right now but i do have both the obI and OBII. Which one should go in there?
  4. reikoshea
    Dallas, TX
    if youve got a p30 or a p2t, those are the ones you should use.
  5. nightrider45
    nightrider45 Junior Member
    b16a sir2, you have the P30 ecu thats an OBD1
