B16A2 INTO CIVIC EG
Discussion in 'HYBRID -> EG-EK / DC' started by BIG.GEOFF.H, Jun 27, 2005.
  1. BIG.GEOFF.H
    BIG.GEOFF.H Junior Member
    HELP!
    I HAVE A 93 CIVIC EG WITH A D15B2 RUNNING OBDO ECU AND AM FITTING A B16A2 FROM 97 CIVIC THE ECU IS OBD2A ALL THE ENGINE AND TRANNY IS BOLTED IN IM JUST A BIT STUCK ON THE WIRING CAN ANY BODY GIVE ME A BIT OF LIGHT ON WOT 2 DO PLEASE
    MANY THANKS :worthy:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Wire the vtec, knock sensor, and o2, run an OBD I to OBD II conversion harness at the ECU. Is the motor plugged into the car? If so, what harness did you use?
  3. BIG.GEOFF.H
    NOTHING IS PLUGED IN AT ALL I GOT THE FULL ENGINE HARNESS FOR THE B16A2 INC ECU AND THE ORIGINAL CAR HARNESS IS STILL IN. THE PLUGS ARE DIFFERENT DONT WANT TO START CHOPING AND JOINING UNTIL I KNOW FOR SURE WOT GOES WHERE, AND WHERE DO I GET THE HARNESS FROM TO CONVERT OBD0 - OBD2?
    THANKS
  4. BrowNKiD
    BrowNKiD Member
    Toronto, Ontario, Canada
    try turning off caps lock
  5. jdmeg6
    jdmeg6 Senior Member
    So Cal
    :werd: Yelling that shit aint gonna get the answers any faster!
  6. BIG.GEOFF.H
    I do appolagise people im not good with computers didnt know it was offensive and shouting mith the caps lock on
