Al_Aspirated
Sorry I have not introduced myself the proper way (Again). I am copying and pasting this off a different forum that i posted this thread in. I really need to get this going and for some reason I haven't been able to get the information I desperately need!
I have a 1992 Civic DX (EG) I have a B16A2 motor with no transmission, computer or harness. Currently in my car I have a D15B7 (Non Vtec) with the stock econo-gearbox. I want to find out some important information about doing this swap.
1. Is it possible to use my econo-box transmission with the B16A2? I know the outcome will be slower acceleration due to the gearing.
2. Will my stock wiring harness (with proper modifications) work with this motor and still hit Vtec with the proper ecu?
3. What kind of ECU would I need? Mind you that my car is OBD-1 (Obviously) and i'd still be using the OBD-1 Harness. Would i need a computer out of a Vtec del-sol?
Also, this motor came out of a 92 Integra in which i took the motor/trans mounts out of. If i am not mistaken these mounts should fit my EG with the B16A2 Correct?
Any input will greatly be appreciated!!!!!!!
