B16a2 knock sensor wiring
Discussion in 'HYBRID -> EG-EK / DC' started by auto_tech, Sep 29, 2005.
  1. auto_tech
    auto_tech Junior Member
    Hey guys, I need to know exactly how to wire up the knock sensor to the cannon plug. I have some instructions but it is only showing me one wire, and as far as I know the knock sensor is 2 wires correct? On the back of the block, little electrical plugs right? Well I was told one goes to the ecu (pin D3), and the other one is ground, so I need to know which one is ground, the connector on the left or right on the plug. Please correct anything that isn't right, just want to get all this wiring crap done, i got everything else set up ok so far. Thanks in advance,
    -Aaron-
  2. reikoshea
    Dallas, TX
    umm the wire that goes to the ecu is red and blue on my prelude...thats the best i can do.
    Its dark right now, and all i have is a scissor jack at my house. i can probably look tomorrow since i will be changing my Header and Down pipe.
  3. auto_tech
    I am not sure if the knock sensor would be the same on the h-series motors or not. But if you can take a look, and let me know which one of the wires is grounded, the one on the left or right. THanks.
  4. reikoshea
    Dallas, TX
    I know the sensors are the same. at least if you buy one on ebay it says b and h series knock sensor.
  5. auto_tech
    Ok, then all I need to know is where the wires go, one to the ecu, but which one? and one is grounded possibly. Let me know someone!!
  6. Punisher
    Punisher Member
    I've seen a couple of knock sensors. They are all one wire. Presumably the knock sensor itself is grounded when attached to the engine block.
  7. PhyRe
    PhyRe Senior Member
    ct
    i may be wrong but i dont think the b16 has a ks. i thought only the b18c and h22 had them [​IMG]
  8. auto_tech
    The b16 definetly has a knock sensor. You could look this up by searching the wiring instructions up on the web, knock sensor is included. I have figured it out though. Knock sensor is only one wire. Thanks guys.
  9. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Only B16A that I know of that doesn't is mine, and the other european ones. JDM, USDM's have them.
    KS = one wire.
  10. jamesA
    Just so he's clear on which one it is, what color is the KS wire? I'd assume the ground wire is black.
  11. xj0hnx
    C.C.TX.
    Off the top of my head....can't remember, but it's posted in here several times.
