What exactly would be required as far as wiring to swap in the b16a2 (from an 99 si) into a 92 si which is obd1? i've looked around and read conflicting info.
and what are these conversion harnesses? do i need the 99 si engine harness?
Originally posted by clevisR6@Aug 4 2005, 07:21 PM What exactly would be required as far as wiring to swap in the b16a2 (from an 99 si) into a 92 si which is obd1? i've looked around and read conflicting info.
ok, i think i found some info:
the 99 si harness is a one piece, so not good for swap?
so,
1. can i use the eg harness with a adaptor harness from hasport? would anything else have to be modified; injector plugs, alternator plug, etc?
2. or would i be able to use a obd2b integra harness since tegs and eg's are the "same" sort of? would they be 2 piece harnesses also? would i need a hasport adaptor? if so, which one?
98 Type R or GSR harness.
99.5% plug and play, no component changing required.
2 wires for IAT need to be extended.
Rear ANDDD side motor mount BRACKETS from a 95 GSR.
LS axles.
