B16A2 Rev and Speed go up but car doesnt move
Discussion in 'HYBRID -> EG-EK / DC' started by joshb2006, Apr 8, 2011.
  1. joshb2006
    joshb2006 New Member
    Hey guys,
    Not going to bore you all with a long story...
    situation: Starter bolt bracket broke, so JB welded the bracket back on, replaced, started fine, was driving down the highway and hit a bump, all of a sudden now...
    Car in ANY Gear = NO movement..
    When using the gear shifter it just slides into any gear with/without the clutch in.. it doesnt seem to make a difference.
    I can HEAR the gearbox putting it into gear, and even REVERSE will not move the vehicle.
    when in 4/5 gear it sounds like somethings grinding.. while it just sits in gear with no clutch it or anything.
    Now.. : I changed the clutch 650KM ago, everythings been fine, no problems what-so-ever. this happened on the highway while in 5th gear doing 110KM/H.. not speeding, anything.
    Any help/suggestions/tests would be great thanks guys!
  2. joshb2006
    Also when I give it gas it any gear or neutral, it revs so quick and the actual speed sky rockets to like 200km lol..
  3. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    Never heard of this happening before, but it sounds like the trannys f'ed
  4. 98EkSi
    98EkSi New Member
    Sounds like you need a trans. I bet if you drain the gear oil you will find lots of metal partials in it.
  5. joshb2006
    Alright man, I will check my fluid today, I just filled er up 2 weeks ago. Will post an update tonight :)
  6. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Differential or maybe the clutch? but the starter fix makes me think about the flywheel......Take it out and look at the clutch/flywheel first.....then you might need to get into the trans or buy a used one.
  7. joshb2006
    Hey Cafrog,
    Thanks for taking the time in lookin into this, you've helped me before and its really appreciated.
    I just had the flywheel Resurfaced and a brand new clutch(650KM so far) into it, also replaced the throw bearings, etc full clutch kit.
    The reason the starter went is because it only had 1 bolt in it and it wasnt all the way tight(good job mechanic) and so the bracket broke, got a new starter today so im going to install that when I get home and also check the tranny fluid for metal flakes.
    Will update this in about an hour and a half.
  8. jgpoirier
    jgpoirier New Member
    I'd agree with tranny effed. Being speed sensor is acting up at the same time.
  9. joshb2006
    Problem Resolved...
    idiot Mistake..
    When i remove the alterntator, I forgot to bolt back up the halfshaft for the axles.
    Epic fail.
    Lol
